Thanks!
There might be a crash happened under the hood, investigating this as we speak. ![]()
Thanks!
Oh right, which Linux distro and version were you on?
AlmaLinux 9 and Maya 2023.3
Hi @micdin ,
I have another new release for you, it will print more messages that should help us debug.
Please have a try, thank you.
The latest version works now, thank you. We will be testing it now and I will report if anything else breaks.
Just out of curiosity, are you allowed to elaborate on what was wrong?
Oh wow thatâs great news!
Just to be sure, can you test this version? This version has those extra debug messages removed.
Thank you so much. ![]()
Update: Oh and, about the fix from previous release, other than adding debug messages, it was hiding symbols from loco3d executable. Perhaps there was some kind of collision/conflict.
Hi,
iam a collegue of @micdin and we are currently doing RnD with Locomotion.
Unfortunately i encountered a new problem when i want to bring the âPlan to Animationâ.
Then i get this error:
Do you know whats going on there?
Hi @alesch and welcome to the forums ![]()
From the error message, the rPlan node might get deleted or renamed at the time you call plan_to_animation().
What were the steps you took before calling plan_to_animation()? Also, can you confirm that rPlan node, rPlan_main still exists?
Thanks!
Hi,
thanks for your fast respond.
That is the strange thing. I did not delete the rPlan node. Tried it also again in a new fresh scene. Same result.
The rPlan node is there.
Ah ok, so the problem is that additional empty group ârPlan_mainShapeâ.
The error message did not do a good job on revealing the problem. At the moment it wonât work if there are other node has the same name as rPlanâs shape node.
Is it possible to rename that empty group? But if it was generated from Locomotion plugin, then it is a bug.
And hm, I just realized that this thread was more about the issue of loco3d executable, so if you have more update on this one, please open another thread. ![]()
Thanks!
hi,
renaming the group did the trick.
and yes⌠everytime i âAssign a Planâ it creates the group with the same name like the rPlan node.
So its maybe a bug?
Sounds like it, weâve added it to the list, thanks for your patience.
@davidlatwe & @marcus initial testing with these versions appears to solve the issue @craigb and we were having.
Heads up the latest download version on your website is older than the latest ones referenced here and it still has the problem.
Thanks for debugging and finding that everyone. Ill let you know if this particular error persists in anyway.
Thanks for the heads up, however they are one and the same. The version listed is the one for Ragdoll, not Locomotion. They have their own version numbers (as they update independently). A little confusing, itâs true.
