When using Ragdoll’s Import Physics on an imported object, I get an error on Create Missing Transforms. If I do Import Physics directly to the referenced scene, it works fine. Is there something wrong with the operation?
// ragdoll._create_missing_transforms() - Creating missing transforms…
// Warning: ragdoll._import_physics_wrapper() - Traceback (most recent call last):
// File “C:\Users\UserName\Documents\maya\modules\Ragdoll-2023_04_06\scripts\ragdoll\vendor\cmdx_ragdoll.py”, line 6840, in createNode
// mobj = self._modifier.createNode(type, parent)
// TypeError: parent is not a transform type
// During handling of the above exception, another exception occurred:
// Traceback (most recent call last):
// File “C:\Users\UserName\Documents\maya\modules\Ragdoll-2023_04_06\scripts\ragdoll\interactive.py”, line 4202, in _import_physics_wrapper
// _singleton_import_loader.reinterpret()
// File “C:\Users\UserName\Documents\maya\modules\Ragdoll-2023_04_06\scripts\ragdoll\internal.py”, line 480, in _undo_chunk
// return func(*args, **kwargs)
// File “C:\Users\UserName\Documents\maya\modules\Ragdoll-2023_04_06\scripts\ragdoll\dump.py”, line 751, in reinterpret
// self._create_missing_transforms()
// File “C:\Users\UserName\Documents\maya\modules\Ragdoll-2023_04_06\scripts\ragdoll\dump.py”, line 804, in _create_missing_transforms
// transform = mod.create_node(“transform”,
// File “C:\Users\UserName\Documents\maya\modules\Ragdoll-2023_04_06\scripts\ragdoll\vendor\cmdx_ragdoll.py”, line 5710, in decorator
// return func(self, *args, **kwargs)
// File “C:\Users\UserName\Documents\maya\modules\Ragdoll-2023_04_06\scripts\ragdoll\vendor\cmdx_ragdoll.py”, line 6843, in createNode
// raise TypeError(“‘%s’ is not a transform type,” % parent)
// TypeError: ‘<OpenMaya.MObject object at 0x000001DACDEDD570>’ is not a transform type,
// Warning: ragdoll._import_physics_wrapper() - An unexpected error occurred, see Script Editor
This was tried in a very simple scene to limit the problem. The tiger tutorial could not proceed successfully due to the same problem.
