Hello there,
I am following along the Manikin I tutorial and seem to have this issue where when I attempt to assign and connect markers to the Manikin Rig, the members of the group are not visible and the markers are placed at the origin of the workspace.
I am using Blender version 3.6 with version 2024.04.15 of Ragdoll Core and Blender Addon.
Any help would be apprcieated!
              Hi @VickyDP, welcome to the forums
Could you be using an Intel GPU by any chance? Are you able to open the Console to see if any of these messages appear for you?
https://forums.ragdolldynamics.com/t/nothing-happen/1410
              Hi @marcus, thanks for the quick response!
Im running an AMD Ryzen 5 3600 CPU and AMD Radeon RX 5700 XT GPU on Windows 10 OS. The error that pops up in the system console is similar to the posting you linked. I’m pretty sure that AMD supports OpenGL so it might just be my drivers being outdated. I’ll give them an update and see if it works.
Update
Still same error with updated drivers
FAILED TO LINK SHADER:
ERROR: Linking vertex and fragment stages: Types must match:
vertex stage: " vec3 Color"
fragment stage: " vec4 Color"
Vertex path:
gl_shaded_marker.vert
Fragment path:
gl_shaded_marker.frag
Ragdoll failed to init OpenGL renderer: could not load gl_shaded_marker.vert/fragFAILED TO LINK SHADER:
Vertex path:
Fragment path:
              Thanks for this, yes this isn’t an issue with your driver this one is on us. The drivers we’ve tested with has been very forgiving to this bug we’ve written, but not all drivers are.
I’ll try and get a patch out for this asap.
              I’ve pushed a possible fix for this now, please give 2024.05.23 a try. You’ll need to update both Ragdoll Core and Blender for this one.
              Thanks so much for the update, it all seems to be working on my end now.
