Hey there! Just tried to install ragdoll to try it out, but the menu would not be created. I just get a Warning (title) about it and after searching a bit online I haven’t found a solution.
If I run the
from ragdoll import interactive
interactive.install()
code in the download section I get a different error: Qt.py line 1961: No Qt binding were found.
I’m a bit stuck so I just wanted to ask if I’m missing something here
Sounds like a bad install. How did you install? What platform are you on, and what version of Maya? Ragdoll supports Windows 10+, Linux (CentOS/Rocky Linux) and MacOS, along with Maya 2019-2026.
And how did you load Ragdoll, it should happen via the Maya Plug-in Manager window.
I downloaded the .msi and ran it, restarted maya, and ticked ragdoll in the Plug-in manager. Don’t think I did anything wrong there but maybe something weird happened
And once loaded, you should be able to run this in your Script Editor.
import ragdoll
If that didn’t work, then have a look at what this prints.
import sys
print("\n".join(sys.path))
It should be 10+ different paths on your file system, one of them should point to that modules folder. Even without Ragdoll having been loaded.
If it isn’t there, that suggests the .mod file isn’t found on your system. So check your MAYA_MODULE_PATH.
import os
print("\n".join(os.environ["MAYA_MODULE_PATH"].split(os.pathsep)))
This too will print a number of paths, one of them should be to that modules directory. If that isn’t the case, then you have a non-default Maya install; typical in a production environment. What you then need to do is move your Ragdoll install to one of those paths. That’s where Maya will attempt to look for modules such as Ragdoll.
Let me know how it goes and we’ll take it from there.
didn’t work, but when looking at the things it printed from
import sys
print(“\n”.join(sys.path))
I couldn’t find any from ragdoll, but I did find some from other tools in the modules folder. And taking a look in that folder, there’s the .mod files and follders from those tools as well as the one from ragdoll. I have a Ragdoll-2025_10_06 folder and a Ragdoll-2025_10_06.mod file
Given that you can open the Plug-in Manager and spot Ragdoll there, that means the .mod file is found. That mod file is what makes the ragdoll Python library accessible too, so it’s odd that it doesn’t.
Are you able to test on a separate machine? How are you launching Maya, is via the Start Menu or some launcher program of sorts?
Ok, let’s try doing what the module does manually.
import os
import sys
from maya import cmds
# Replace me
version = "2025_10_06"
def find_pythonpath():
for path in os.environ["MAYA_MODULE_PATH"].split(os.pathsep):
ragdoll_path = os.path.join(path, "Ragdoll-%s" % version)
if os.path.exists(ragdoll_path):
pythonpath = os.path.join(ragdoll_path, "scripts")
assert os.path.exists(pythonpath), "Missing 'scripts' path"
ragdoll_package = os.path.join(pythonpath, "ragdoll")
assert os.path.exists(ragdoll_package), "Missing 'ragdoll' package"
return pythonpath
pythonpath = find_pythonpath()
assert pythonpath, "Could not find Ragdoll's python path"
if pythonpath not in sys.path:
print("Added '%s' to PYTHONPATH" % pythonpath)
sys.path.insert(0, pythonpath)
else:
print("'%s' already in PYTHONPATH" % pythonpath)
print("Loading Ragdoll")
cmds.loadPlugin("ragdoll")
Replace the top “version” with the version you have on disk, and run this. It should load the plug-in like you would via the Plug-in Manager, except it will manually add the missing Ragdoll package to Python before hand.
it returned this:
‘C:/Users/lukkram/Documents/maya/modules\Ragdoll-2025_10_06\scripts’ already in PYTHONPATH
Loading Ragdoll
Warning: ‘ragdoll’ Python package could not be found, no menu will be created
Error: line 1: Plug-in, “locomotion”, was not found on MAYA_PLUG_IN_PATH.
Error: Failed to load locomotion.
I also tried after runing the .msi for locomotion and it returned this instead:
Error: NameError: file line 24: name ‘sys’ is not defined
Added 'C:/Users/lukkram/Documents/maya/modules\Ragdoll-2025_10_06\scripts' to PYTHONPATH
Loading Ragdoll
# Warning: 'ragdoll' Python package could not be found, no menu will be created
# Warning: 'locomotion' Python package could not be found, no menu will be created
// Locomotion is loaded
Aha, I think that’s the culprit. On your system, I suspect there is an environment variable forcing the Qt wrapper (Qt.py) to only consider PySide2, which was what Maya 2024 and below was using.
The environment variable is called QT_PREFERRED_BINDING and you can confirm by running this.
import os
print(os.getenv("QT_PREFERRED_BINDING"))
This will likely print "PySide2". It would be set either via your global Windows Environment Variables manager, or any launcher script you used to launch Maya with.
If so, then your safest bet is to try and understand why this was added in the first place, and ideally remove it. Alternatively, you can add PySide6 to it.
Great to hear it’s now solved. This one is hard to address on our end… That Maya 2025 session is misconfigured and unable to use Qt.py for any project that uses it.
That said, the error message could definitely have been more descriptive. Thanks for reporting this and let us know if you run into any other issues!
