I just ran into this and want to make an entry here on the forums in case anyone else runs into it and searches for it here.
2022-07-30, 13:15:12 <error>: This TurboFloat Server is not activated anymore - exiting immediately. (Error code: 0x1). You must activate this TurboFloat Server via commandline like this:
TurboFloatServer.exe -a="ABCDE-FGHIJ-KLMNO-PQRST"
Does it affect me?
This can happen under this exact circumstance.
- You have a Floating Licence
- You have activated the licence server on a virtual machine (VM)
- It was activated online, as opposed to offline
In this circumstance, the licence server will attempt to re-validate itself every day, per default. Which should be fine! However as it happens this licence server can sometimes get a false negative and suspect that your licence is no longer good.
How can I avoid it?
To address this, the author of the licence server software kindly suggests you use real hardware - i.e. not a VM - or increase the delay between each re-validation. Thus reducing the odds of it happening.
In your licence server configuration file, you’ll find this line.
TurboFloatServer-config.xml
<isgenuine days_between="1" grace="7"/>
Change this to:
<isgenuine days_between="90" grace="14"/>
And it will now re-validate every 90 days instead of every day. Reducing the odds of this happening by 90x. A good deal.
How often does it happen?
In my experience, this has happened twice in one year of using this server software, and I have not had any reports from customers of it happening.
- First time after 28 re-validations
- Second time after 7 re-validations
So at best this should give you 28 * 90 days of peace of mind, and at worst 7 * 90 days.
It happened to me, what can I do?
If it should happen, simply re-activate again.
turbofloatserver -a="your-key-here"
For complete peace of mind, monitor the tfs-log.txt file for this particular message and re-activate automatically.
Hope it helps!
