The name of the group created after grouping multiple groups isn't intuitive
My intuition tells me that the new group should inherit the name of the last group I selected, but it seems to use some other method that produces unpredictable names (probably something to do with being the last in the markers chain?)
Wrist group + Cup group = PinkyFinger group(???)
:sweat_smile:
I suppose you are right, I’m going to file this under “Nice to Have”. You can still rename the group post-creation, the initial name is merely a suggestion. You can also wrap Ragdoll’s grouping command inside of your own to pick any name you choose, and make it a shelf button.
ri.group_markers()
The command for which which will be printed for you in the Script Editor as you click the menu item. Also, pro-tip for Maya in general, you can middle-click on the Ragdoll menu, or Edit menu inside of it, to re-run the last menu item.
