Hello, I’m new here.
T key does not work, even if I run Reset T Key or specify another hotkey in Option, it does not seem to work. I see Suceess in the console in run reset.
Hi @AGEnt, welcome to the forums! ![]()
In your Hotkey Editor, what does it say under “Show Manipulators”?
This is the hotkey Ragdoll uses for the Manipulator. Can you confirm whether the Ragdoll → Manipulator menu item works for you?
The hotkey was not assigned, so I assigned T. I was able to confirm that it worked. Thank you!
