Hey @marcus … 10 cents to the cause !
I’ve been playing with “Fileds” to produce and control the animation. the idea of having slider instead of ON- OFF to activate or deactivate the field per marker could be nice !
Cheers ! Lates version is GREAT
Thanks @Andrei_da_02, are you thinking of 2 features here?
Magnitude on the field to control the amount of influenceField Amount attribute on each Marker to control the amount of all affecting fieldsAm I getting that right?
Fields per Marker (as opposed to per Solver), with the Magnitude on the field to control the amount of influence /// Yes, For example… let’s say I apply a Turbulence or Air to biped, but instead of turning off the field inside the advance attrs of the market. I could just control the influence, so it does not go too crazy.
A Field Amount attribute on each Marker to control the amount of all affecting fields // Yes I think that could be handy and more and more freedome.
Thanks !
Ok, but to clarify, you can already control the influence via the Magnitude attribute on each field.
https://user-images.githubusercontent.com/2152766/230313433-16e70809-7227-486c-9461-a9243ffef8dc.mp4
And what you are looking for here, is to specifically lower the amount of influence for individual Markers?
yes, sr !
It might be very specific…! but for example if the Field is affecting too much the small markers likfe fingers or hands … then it could be toned donw… or even animate it … that could be nice.
Yes, I am aware of the magnitude and types… I am playing with all the values of the fields, creating animations from there…! it is fantastic!
