If you’re getting Jittery simulation - check your actual scene scale,
in this video I have debris falling and got some fast calculation times BUT if these chunks are too small I get slower simulation times.
One suggestion is to simulate your scene at a larger scale and scaled your scene back down.
This is because of a different variable, also called “Scene Scale”.
The problem
When things move too fast and are too small, things will have trouble coming to rest. It’s because of assumptions Ragdoll makes about the overall size of most objects, and per default it assumes that no object is smaller than about one Maya grid cell (1 cm).
The solution
This generally only needs to happen once per studio or per project or per user, as most things are safe to assume to have a relatively similar size to each other.
- Go to Ragdoll → System → Preferences
- Set Scene Scale from 10 to 1
This however will not have an effect until after you reload the plug-in.
Elephant in the room
What is the difference between Scene Scale in Preferences and
Scene Scaleon therSolvernode?
Yes, these are poorly named…
Preferences Scene Scalerefers to internal thicknesses, specifically related to motion coming to restSolver Scene Scalerefers mainly to gravity and how quickly things fall
You probably didn’t know about Scene Scale in Preferences, nor have you ever had issues with things coming to rest without jittering. Because naturally, you tend to size things relative the Maya grid. And that’s good! That’s the assumption the default values were based on.
But sometimes, like in Jason’s scenario above, you encounter a scenario where it would be useful.
Why not keep a low Preferences Scene Scale all the time?
I invite you to try! There is instability at the other end of the spectrum as well. Where things that are too large start having trouble coming to rest. It’s a hard problem, as is scene scale in general. Hence this is a user-tweakable variable, such that you can find what works best for you.
I find the easiest solution, I have a astronaut character and that has 633 markers with all his stuff and when I try to add this in main scene character was very big, I try to scaled it but character just exploded, it was not like that in simulation, scene scale can’t help, so I just turned off all things in Maya viewport, i just left polygon and curves, i scaled character with curve that was parent of character than turned on all in viewport and it works, every marker work with gravity perfect
Hey welcome to the forums @Amiko, sorry for the sluggish reply, on holiday for just a few more days over here. Great to hear it works!
Scaling the character should still work without any viewport changes though, the one thing that wasn’t scalable until the latest release were Distance Constraints, but other than that everything is scalable. It could have been that you need to return to the start frame after scaling.
If you or someone else runs into this again, let me know here and I’ll investigate why it didn’t work.
Thank you for your reply, so there was lot of constrains, there was lot of stuff connected to character and to each other, that’s why my character exploding after scaling, but I fixed it and it works, I changed solver strong to stable, it help well
