I’m trying to setup a tail, and I was wondering if there’s a way to setup stiffness on the markers per axis. I would love to get some really loose follow on the side to side motion, but being able to keep it steady on the ups and downs.
Is there a way to do that?
After testing the two attributes, twist and swing, they do almost what I want, specifically the swing one, which loosens the motion of the tail, but as it still does it on two axises, the result is a very droopy tail.
Any other suggestions to achieve a more rigid tail that swings left and right more freely but doesn’t drop down to the floor?
Yes, I can think of one other way, which is to limit the axis you want to see less motion on. Limits also have a Stiffness and Damping and can be tuned in a similar way to Rotate Stiffness and Damping. The limitation being that the values cannot be animated.
Notice how I reduce the amount of rotation it can have on the up/down axis. From here, you can tune the values to achieve the look you want.
