Hello everyone ![]()
I am going to try and make a short animation, a crab jumping rocks to cross a river, with Loco Motion.
Disclaimers:
I have almost no ideas about the workflow and only seen a livestream that hosted a few days ago with documentation on the release page.
So the first thing to do is testing how loco motion works, and how to walk and jump.
Some notes:
When planning with a ground plan that has not marker assigned but an environment, seems not working. -
Can have only one terrain. But you can combine all meshes and leave the history as is.
Cannot change plan preset once created. (e.g. Jump/Walk)
Cannot freeze transform on body and foots.
Terrain seems cannot have gap? Or its res not high enough? Wondering if there is a way to visualize what exact mesh/volume that loco engine sees.
I made a gap in between because I thought Loco motion will automatically change to jump from walk
. But, still a bit strange that it landing foot on a point that is not on the ground.
Limit mode flickering bbox(nvm, its because CachePlayback was enabled) -
Need to turn off CachePlayback.
Limit mode doesn’t have mirror edit if not in center, e.g. foot.
Stuck in “Thinking…” when the plan actually updated (message showed in ScriptEditor) and the status changed after I click/move the mouse again. (I cranked up the iteration count so I waited for like 20 secs and found this issue)
Maybe we should have plan blending? At the moment I can blend plans with keying the attribute “blend” on each body parts.
Ok, that’s it for today. Will try to update at least once a week! ![]()
