Request: Markers for multiple bone chains in batches
Hi there,
I was wondering if it could be possible to implement functionality to create markers for simple bone chains in a quicker manner for batch setups
What I had in my mind was to obtain similar results like the Alien rig in your demo solvers in an scenario where we have multiple characters like that with different limb sizes/etc, or for props with many hanging components, things that don’t really require that much tuning like a main character but that require a lot of manual work
I’ll try to describe roughly what I had in mind
  • Specifically I would like to be able to select the root bone of a chain and click on the end of that chain and have a shortcut to assign and connect the whole chain at once without having to select each bone.
  • Better than that it would be to have a shortcut from the root and have the markers progress in the direction of the bone orientations until they meet the end of the chain
  • Ideally it would display a preview of the markers before confirming the setup. Something similar to setting up a Bevel when you are modeling in Blender, you see the result, and scroll up and down with the mouse wheel to change the settings, on this case a scroll could let you progress further in the bone chain, or come back from a chain if it overshooted and you want to set the markers between bones that are intersecting.
Example of this case:
The chain gets generated but it doesn’t know where to end, it could pick a side, end on an intersection point, or fully chain both (these alternatives could be selected with shortcuts too including scrolling through the selection of individual chains?)
Then with the mouse wheel we can scroll down to deselect across the chain of bones for refirnement:
  • On this preview state you could also offer the possibility to press something like S and scale all of the bones at the same time. Maybe if you press O and scroll the mouse wheel you could offset this factor by making markers at the start of the chain bigger than the end of the chain, if you press F it could flip this offset, making the start of the chain smaller, and the end bigger, controlling the offset factor on this state, then returning to scale making again all the chain and bigger and smaller proportionally with the mouse wheel
  • Another possibility would be to set up all the limits at once for the current chain, all X angles, all Y, all Z. With offset or without offset too (similarly to to modifying the scale on all selected bones at once ) this way the root could have a different limit than the end of the chain to create variations
This kind of workflow could easily solve cases like:
The reason I’ve been thinking a lot about this is because lately I’ve been using very large rigs to have fine tune control over things that are often done procedurally or with simulations.
I’ve tried things from creating world space empties to move things around with proportional editing, but this ignores interactions between bones. To use blender own IK and rigid body solvers with horribly unpredictable and very slow results, to use geometry nodes and having things look… well, procedural, which if we are on this forum by default we know we would like to animate many of the things we often can’t.
And I must say, I understand you guys are working hard on a new rigging schema and that also when users often mentioning something like batch asset processing, automated settings and things of that nature in software it sounds like a lot of this detail oriented workflow misses the point of the originally intended use of the software, or that it asks to account for things that can’t be generalized.
But the reason why I’ve limited the description of the features to basically selections, scales, and offsets is to make the asset processing of less critical parts of the pipeline more efficient to be able to use Ragdoll in scenarios where it would be too time consuming to use otherwise.
Just to give a real example, the last test I ran on a project I immediately regretted it when I realized that I had close to 500 bones across multiple chains. That Bendy bones wasn’t gonna cut it, and that a physical approach was needed while still needing to preserve the capacity to rig and cleanup afterwards
At that point was where I appreciated all the speed optimization mentioned in the news section of the documentation. Ragdoll’s library and those solvers you guys implemented are like alien technology, I have no other way to describe it. I was initially attracted by the live mode and the core functionality of the software but after dealing with all of this I now see why so many have stumbled upon the math wall that is trying to make a quick solver and decided to just walk away and try something else, it’s crazy just how bad the performance of everything else was in light of that scenario but ragdoll was the only thing on the scene performing on real time
Unfortunately, setting up the rig would’ve taken too long so I had to opt for simulation nodes. But if something like this could be implemented a lot of the limitations from blender could be ignored and in a more performant way for things that otherwise couldn’t take advantage of ragdoll for time constraints while still keeping the capacity to fine tune the animation
And of course, by having this as a possibility it would be just way more convenient to set up simple FK chains with no special controllers or dependencies if at the end of the day Ragdoll would handle that part of the animation. Many doors open in the pipeline if this was possible.
Thanks for this well-thought out feature request!
This is true. There are two major categories for simulation.
  1. Massive scale simulations, like particles and destruction and procedural animation
  2. Nuanced detail, like secondary animation
We primarily aim to solve (2), due to there already being many capable solutions for (1), such as Houdini and Blender’s own simulation nodes. We as a company believe that what the world of film and games lack is not large-scale simulation solutions, but rather solutions for single-character animation and character-to-character interaction. This is where film and games fall flat at the moment, this is the part that needs the most care an attention.
That said, we’ve incorporated a powerful API with Ragdoll, the same API we use to integrate Ragdoll Core itself. Meaning you can script your way to just about any feature your heart desires.
For example.
Here’s what this looks like in Python.
# Get the current selection, which should be a single root Bone
selection = bpx.selection()
root = selection[0]
# Walk the hierarchy to find every child
chain = []
def walk(root):
    chain.append(root)
    for root in root.children():
        walk(root)
        # In case of 2+ children, only walk the first child
        break
walk(root)
# Call on the default Assign Markers operator
bpx.select(chain)
bpy.ops.ragdoll.assign_markers()
And here’s that same Python script wrapped in an operator you can install to assign this to a shortcut, like I did in the video.
ragdoll_multi_assign.py (1.7 KB)
If you wanted to incorporate a second selection to limit how deep it walks the hierarchy, then the walk function is where this would happen.
def walk(root):
    if root == second_selection:
        return
Let me know if this works for you or if you need any help expanding upon this operator. If you end up incorporating drawing with this operator, e.g. for your suggestion for middle-wheel scrolling for depth etc, then feel free to post it here and we may incorporate it into the next public release.
That’s amazing! I didn’t even realize about the API
I know next to nothing about python or coding but this makes a lot of sense, I didn’t think going up the chain and call the assign markers operator at the end, that’s very straight forward.
I’m reading about BPX on GitHub, this means that the order of the bone selection is kept with this wrapper?
This will work perfectly. I will play a bit with this and see what ideas I can come up with
Yes absolutely, what I see here is that we could use dense rigs for things like stylized hair or props and preserve a blend of simulation while still being able to individually direct and pose these objects when needed. I just wanted to be able to consider them just like the rest of the character for certain situations. I took those demos @marcus did with the cloth and hair rigs to heart
I found these links, is there anything else I should be aware or is everything included in here?:
https://github.com/ragdolldynamics/ragdoll-blender/tree/main/ragdoll/operators
https://github.com/ragdolldynamics/bpx
https://github.com/ragdolldynamics/ragdoll-blender/blob/86fabb7e60b2bff4a0397be1e6f3520b63235199/ragdoll/commands.py#L72
I saw that the cmdx page is a lot more dense so I don’t know if it’s because you guys are still working on the documentation or because it’s just a lot more simpler by default on Blender
Correct, you can separate between first and second selection like this.
first, second = bpx.selection()
Those should get you going, except the version of bpx.py on GitHub is older than the one distributed with Ragdoll at the moment, so use this link instead (if you need to reference bpx):
For some jargon, “operator” is native Blender speak for “some action”. When you run any kind of command, you call on an operator. When you bind a hotkey, you bind them to operators. That folder is where all of Ragdoll’s operators are, and is what is called when you run items from the Ragdoll menu.
The Manipulator operator is especially relevant here, as it remains active (called “modal”) after being run, to intercept keyboard and mouse events.
Are you referring to the wrapper used with Ragdoll for Maya, here?
It’s got a few more years behind it and is a lot more general than bpx.py, which is currently quite specific to Ragdoll and wouldn’t make as much sense to use elsewhere.
By all means, if you need help understanding bpx, feel free to post here.
Awesome, that’s very interesting. I can work with that
I will! Thanks a lot
