I turned on the Extract faces but replaced mesh didn’t change its shape?
Hi @DWKAi, welcome to the forums! ![]()
The reason this happens is because the replaced mesh did not maintain history. In the options for Replace Mesh, tick that box and you’ll see changes happen in real-time.
Alternatively, after you’ve cut the mesh, replace the mesh again to see the changes.
The reason it does not maintain history per default is to avoid assigning a skinned mesh and have it deform after having been replaced.
The issue has been resolved, thank you for your reply!
