... Ratatouille" ... // Just having Fun with fileds
Hey gang !
I want to share this example/ exercise that I’ve been playing around.
I have been done using “Air” field and a “Pin” to drive the rotations and direction of the … that’s it !
I did a pretty cheap proxy of the geo … (While I find a proper RAT model)
this Image shows the only object that is animated on this scene:
I pretty much connect the values of the Field that I wanted to animate to control the character to a Locator with some custom attrs.
more to come !
thanks to the generous “Master of Puppets” ! XD … :nerd_face:
Soo much fun!!! New path sim anim
You can animate the Direction XYZ values, but it’s kind of tedious.
Here’s how you can convert regular Rotate XYZ into Direction XYZ values.
  1. Make a locator
  2. Set Translate X = 1
  3. Group it
Now whenever you rotate the group, the locator will produce Direction XYZ values. So the only thing left to do is connect them to the field.
  • locatorShape1.worldPosition[0] → airField1.direction
Awesome !!! thanks for the tip !!! I will try out for sure
