In Shape Mode, different shapes have different options, but the options don’t appear immediately when you switch shapes. You have to make some kind of change, like scaling the shape, before the new options become visible.
For example, the options for the box only appeared after I scaled it. (this happens to every shape)
Also, why is the box always so incredibly thin by default?
Thanks for reporting this, smells like a bug. Investigating this.
As for why they are very thin per default, their dimensions are approximated from the assigned shape. Assign to an object with volume, and you’d find a closer match to that volume. For those curves on the other hand, they would fit the width and depth, but then their height would be based on an infinitely narrow circle. It’s true it could have a slightly thicker default, but it’s unclear what thickness would make sense for everyone in every situation since the assigned shape itself has no height.
