i was following this tutorial (https://www.youtube.com/watch?v=9m104OR25og) and
doing some test… when i try to pin a marker it wont follow the bones
Hello @rex_rohar , welcome to the forum! ![]()
The recording is a bit far to see how markers and joints were setup. A close up might be more helpful.
But first, I think you can have a look at your Pin Constraint option dialog, make sure to use Constrained mode so the created pin constraint can follow your animated joint.
im actually using blender … the screen shot you shared is from maya.,. but i think in blender there is no option like this, i fixed this problm by manually adding child of constraint to all the pins…
Ah thanks!
Yeah, that’s exactly how pin-constraint following marker in Maya. See if we can squeeze this one into our next Blender addon release.
