Here’s a small simple tool for you to:
- Quick toggling physic force fields!
Just copy the following script into your Maya script editor tab (python) and run it. And you should see a small window pops up with all your fields listed as checkbox!
# RagdollDynamics: Field Toggler
from maya import cmds
from functools import partial
def get_fields():
for solver in cmdx.ls(typ="rdSolver"):
a = str(solver) + ".owner"
for fd in cmds.listConnections(a, s=1, t="field"):
yield solver, cmdx.encode(fd)
def ui_enable_field(field, solver, *args):
with cmdx.DagModifier() as mod:
index = solver["inputFields"].next_available_index()
mod.connect(field["message"], solver["inputFields"][index])
def ui_disable_field(i, field, *args):
conn = iter(cmds.listConnections(i, c=1))
for p, f in zip(conn, conn):
if f == field:
cmds.disconnectAttr(f + ".message", p)
return
def make_gui():
name = "rdSolverFieldsGUI"
if cmds.window(name, q=1, ex=1):
cmds.deleteUI(name)
window = cmds.window(name)
cmds.columnLayout(adjustableColumn=1)
for s, f in get_fields():
_i = s.shortestPath() + ".inputFields"
v = f.name() in (cmds.listConnections(_i) or [])
onc = partial(ui_enable_field, f, s)
ofc = partial(ui_disable_field, _i, f.name())
cmds.checkBox(label=f.name(), v=v, onc=onc, ofc=ofc)
cmds.showWindow(window)
make_gui()
Quick walkthrough ![]()
Hope you find this useful ![]()
