We just got Ragdoll (v2022.12.21) running at work (no internet connection), and I’m trying to get Locomotion to work. I’ve gotten Locomotion to work on my own machine, but for some reason it doesn’t work in my Work machine. Here are some observations:
Using the latest version
Work Machine does not have internet connection, plug-in runs in Offline mode
No error in the Script Editor
Ragdoll Markers work well otherwise
Has anyone encountered this before?
If so, how did you fix it?
What troubleshooting techniques could I try to find out more?
Repeated steps described above. Maya didn’t give me an error.
Terminal however, gave me this:
Ragdoll: I'm being destroyed.. good bye then
Ragdoll: Successfully dropped lease.
pymel.internal.factories : WARNING : trying to remove PyNode for maya type 'rdSolverManip', but could not find an associated PyNode registered
pymel.internal.factories : WARNING : trying to remove PyNode for maya type 'rdGroupManip', but could not find an associated PyNode registered
pymel.internal.factories : WARNING : trying to remove PyNode for maya type 'rdCanvasManip', but could not find an associated PyNode registered
pymel.internal.factories : WARNING : trying to remove PyNode for maya type 'rdMarkerManip', but could not find an associated PyNode registered
pymel.internal.factories : WARNING : trying to remove PyNode for maya type 'rdDistanceConstraintManip', but could not find an associated PyNode registered
pymel.internal.factories : WARNING : trying to remove PyNode for maya type 'rdFixedConstraintManip', but could not find an associated PyNode registered
pymel.internal.factories : WARNING : trying to remove PyNode for maya type 'rdPinConstraintManip', but could not find an associated PyNode registered
pymel.internal.factories : WARNING : trying to remove PyNode for maya type 'rdPlanManip', but could not find an associated PyNode registered
pymel.internal.factories : WARNING : trying to remove PyNode for maya type 'rdFootManip', but could not find an associated PyNode registered
Computing job with 4 feet...
loco3d: /bin/sh: /sw/packages/external/Ragdoll/2022.12.21/modules/Ragdoll-2022_12_21/shared/unix/loco3d: Permission denied
Failed with 'Solved To Acceptable Level'
Great! I’ll have a look to see if there is anything we could do on our end to avoid this happening in the future. The file should already have the correct permissions, but it’s possible that the installation method or software used to unzip the software changed it. It could also be that we lose it during the packaging process. Will investigate. Thanks for reporting this!
