These were the last characters. I can finally get to animation!!!
(Well, after I redo the texturing… Because of the way I rigged these last three characters, I actually lost the UVs and will need to repaint them.)
MetaHuman is for the facial rig, as well as automatic joint placement and skin weighting for the body.
Advanced Skeleton is for the body rig.
Ragdoll Dynamics will help with the animation. There won’t be a single second in this entire animation that Ragdoll doesn’t touch. It’ll be used as an “Improved Spline”.
Thanks for sharing, looks really great. Especially the hair, great idea to make it thick shapes like that, it will produce great motion. Have you reduced density for it? Else it will act like two big water balloons stuck to her head. Hair is basically 99% air, so a density of 0.1 or even 0.01 should produce even better motion, whilst preserving contacts. Oh, and a vastly reduced contact stiffness will help the hair compress if it comes into contact with anything, like hair would.
For the face, did you put Markers there too? Always been keen to explore what can be done with cheek jiggle, but also full-on simulated lips, that offset lipsyncing and incorporate contacts between them.
Oh, great idea with the hair! I didn’t even think about that lol. I’ll also fix all the other characters with long hair…
No, I won’t mess around with the face using Ragdoll. I just learned how to use MetaHuman’s rig and get it into Maya(Then back to unreal). Working with DNA and such a complex facial rig is kind of intimidating. Honestly, I was afraid to even add any extra controllers for the hair, breasts and thighs because I was worried it could somehow disrupt the DNA. So I won’t try to add any jiggles to the face.
For the lower face (nose, mouth, and jaw), I’ll use a video of myself reading the lines (indeed, this animation is actually me telling a story that happened to me, like Jaiden Animations, for example) and use Unreal to translate that into animation, I’ll animate the upper face manually.
For the body animation, I’ll do all the main poses, let Ragdoll handle the “splining”, and then clean up all those keyframes so I can make adjustments.
I’ll push Ragdoll Dynamics as far as I possibly can. Some of the highlights of the animation are:
Dozens of kids running away in fear and pushing each other in a narrow corridor.
Close-ups of intricate hand interactions.
Characters inside of moving car
Four kids dancing and actually interacting with each other, doing acrobatics, climbing on top of each other, and even doing the splits when they fall to the ground.
Not to mention that Ragdoll will be the backbone of every character’s movement.
I have been documenting my progress on Twitter Yuki (@Yuki3DAnimation) / X
