Every release of Ragdoll is 100% backwards compatible for well over 2 years, so if it isn’t working once you update then that’s unexpected and a bug, please let us know!
Actually, I am trying to test the software on a company network.
hehe, I am trying to get more users onboard with Ragdoll workflow!
Might take a long time to get the update version! < I will request for the update from pipeline.
I realise regardless of how I restart it. The frame delay is recurring.
I am using maya 2019. I wonder if theres a preference setting that could break that.
I give the ragdoll version a try with maya 2023. And we do not see the delay.
Hm, one solution is to simply set your kinematic keyframes 1 frame earlier. It’s literally being read from Maya with 1 frame offset, so that should handle it completely.
If it doesn’t, and if it’s fixed with DG, that sounds different. Are you able to reproduce in a scene you can share or post a video of? E.g. with a single joint chain or just a cube?
I see, I think this is fixed with changing from DG to Parallel evaluation. I cant share screenshot as I am on a close network.
I am using maya 2019.3.1
with an empty scene, I created a sphere with ragdoll assigned.
If I am using DG evaluation I can see the delay.
If I change to Parallel, the issue is gone!
