is creating markers using the assign command and then independently reparenting them equivalent to assign and connect?
At the moment I’m using a script which does the former to create a marker heirarchy. It all works great except for one thing I’ve found. When trying to change the rotation limits from no limit to limited the marker flips out. Doing this manually has the same effect it seems.
Just about, the exception being what you are seeing.
When you Assign and Connect, Ragdoll is aware of both child and parent and can orient the limit to point in the direction of the child. When you assign each individually, it does not know this.
You can manually call this orientation function, it’s called Ragdoll → Utilities → Reset Constraint Frames.
It’s also in the Manipulator, here.
When you run it, it’ll spit out the Python command for it, which is:
ri.reset_marker_constraint_frames()
The rotation limits are regular Maya attributes, called:
limitRangeX
limitRangeY
limitRangeZ
You can set these like regular Maya attributes.
Asymmetrical edits is a little more tricky. For that, you need to adjust the range and then compensate by rotating the “parent frame” of the marker; you can find it under the Advanced section of the Marker Attribute Editor.
ok. yep. That make’s sense, but as you say it’s a little bit more involved. I will take a look, but for now we can do it manually using the manipulator which is great.
