Import Physics Broken?
Heyo! Just bought Ragdoll Dynamics today and was trying to save/import a rig setup after spending a good chunk of time setting one up.
On export it seems like everything is working ok, I see a number of exported markers in __ seconds, etc. And Opening up the .rag I see naming and data related to the rig I had created the setup on.
But on import I see no thumbnails, and nothing populates the matches section. Only seeing: “X No Markers found in .rag file”
To troubleshoot I tried this with a basic Cube and the same issue persisted. :x
Any help would be amazing as I’d love to re-use some setups instead of having to remake them each time. T__T
W11
Maya 2025.3.2
Ragdoll Dynamics 2026.09.08
Hi @FujiWizard, welcome to the forums, thanks for your purchase and sorry to hear about your troubles.
You mentioned trying this with a cube, so can I just confirm this is what you tried?
Is there any point in the video that behaves differently on your machine? In your Script Editor, are there any messages when opening the Import Physics dialog or attempting to import?
Well I kid you not, booting up this morning and giving it another go it worked exactly as it should. How frustratingly strange :upside_down_face:
Before, on import it simply wouldn’t load the thumbnail nor would the import matches populate with the exported markers. If I run into it again I’ll be sure to have the script editor open. My apologies for not considering that first yesterday!
Thanks Marcus! Sorry for the false alarm. :slight_smile:
Unplug and plug it in again. A solution as old as time. :slight_smile: Glad to hear it works. If anything else crops up, feel free to make another thread.
