I wants more strong way of selection
Hello.
I using google translate.
Thanks to note that.
I wants more strong way of selection.
How is it going " Drag select about markers. "?
I also wants it.
Link to the part about drag select. ( from docs. )
I wants convert selection.
( Wants multiple OK.)
ragdoll markers → assigned nodes.
assigned nodes → ragdoll markers.
Thanks for reporting this, it’s true drag-select should have been added by now, it has been delayed.
That’s a good idea, I’ll add this to the menu. For the time being, here’s what you can do.
This is the Retargeting UI, and can be accessed via Ragdoll → Edit → Retarget
If you are good with Python, you can also make your own shortcut like this.
markers_to_assigned
def markers_to_assigned(markers):
    assigned = []
    for marker in markers:
        for el in marker["dst"]:
            transform = el.input()
            assigned.append(transform.path())
    cmds.select(assigned)
markers_to_assigned(cmdx.sl(type="rdMarker"))
assigned_to_markers
def assigned_to_markers(assigned):
    markers = []
    for node in assigned:
        marker = node["message"].output(type="rdMarker")
        if marker:
            markers.append(marker.name())
    markers = list(filter(None, markers))
    cmds.select(markers)
assigned_to_markers(cmdx.sl(type="transform"))
These can be dropped into your shelf, for example.
@marcus
Thanks for the code.
It works perfectly as expected.
It was very helpful. :bangbang:
Thank you for your reply.
