Hi
In some fk chains I got the first element flipped when recording simulation.
Not sure what could be the problem. Any idea?
My ragdoll file
flip_problem.rag (2.3 MB)
Thanks
Hi
My ragdoll file
Thanks
Well, I’ve been searching the forum and I found you talked about the Extract simulation tool. The error doesn’t occurs this way and I got something like this
Not sure how I should continue ![]()
It looks this setting I’ve changed in previous tests had to be changed.
Don’t this settings keep by file? If I changed once it remains for next files I work on?
To clarify, do you mean they get flipped when you Record, or when you Assign? Are only the Markers flipped, or does your recorded controls/joints get flipped too?
If you tell/show me the steps taken to reproduce the error, I can try and have a look locally here.
These are stored alongside Maya’s preferences. So if you change it and close and reopen Maya, they will be remembered, similar to Maya’s own UI preferences.
Thanks, Marcus. As you see, I found my stupid mistake. Sorry
