I am exporting physics on a setup and when I reimport it the solver does not have any of the settings. Is this by design? I think it should retain the settings.
Hi Geordie,
I was able to import and have the solver receive and update with the setting updating, are you using default import settings?
I don’t have any options when exporting. I do have options when importing but I can’t seem to figure out what will bring in the setup as I had it. I am not even sure if it’s exporting properly. I’ll have to look into the .rag file and see what values it is storing.
Looks like the solver settings are in the .rag file. Playing around with IMPORT options to see what happens.
Sounds good, when you export it takes into account your whole scene, solver links, constraints etc
