What is best practice for exporting a Ragdoll Setup and importing later on in different scenes with referenced rigs?
It does not seem to work out of the box for me, Markers either don’t import, or they end up in unexpected locations. I can provide images/video later on, but I figured I might start by actually getting a grasp on what’s the best workflow.
Let’s say I have a rig that’s gonna be used throughout different scenes on a project. Where do I create the ragdoll setup for export? In the actual rigfile? Do I reference in the rig, create the setup and then export?
Also, some clarification on namespaces would be great. Right now, I’ve tried exporting/importing physics with namespaces, and the results are unexpected, like I meantioned earlier. Whenever I have a namespace, I also lose “rGround” when importing.
Is there some documention or video that goes over this?
I would love to learn more about what you tried, what you expected, and what happens. Do you think you can write a little bit about that? To us, we work with this every day so many of the first-encounter and first impression issues are invisible to us. Anything you can share here would be fantastic.
The first thing I tried, was to create the ragdoll setup in my rigscene. I want to use it on different scenes on referenced rigs, so my intuition told me that I wanted a way to simply import/export the markers.
Opened up a new scene, referenced in the rig and then tried importing the markers. (Sidenote: rGround gets lost in the namespace here, how do include it? Or how do I create a new ground plane?)
A thing to note, that shouldn’t be an issue though, is that this is a mixamo character with it’s own skeleton. However, to drive this in Maya, that skeleton have been constrained to another skeleton based of Advanced Skeleton. I have done all the markers on the driving rig though (advanced skeleton).
Now, with my crappy trial-and-error tests out of the way, I’ll go ahead and look into the tutorial on how to actually do this. Thanks for directing me to the correct video!
Just checked the video. Perfect, just what I was after!
So my two remaining questions are these:
How do you manage the ground plane? Is it not important, can I assign a general plane as the ground?
Why is my arms/legs off when imported? I realise that this is because of me assigning markes to the IK setup. I followed the documentation on this and here are the steps I took.
a) Assigned markers to the upper body.
b) Starting with the root controller, I selected the root, hip JNT, knee JNT and foot JNT.
c) Assigned markers
d) Retargeted the hip and knee JNTS on to the knee polevector controller.
e) Retargeted the foot JNT to the foot controller
Also, if you’re looking for first impressions on how to get into Ragdoll from a newbie:
Your documention, video tutorials and support on the forums are absolute top class. They are just the right amount of information, presented with absolute clarity. The tool itself is very intuitive as well.
What I typically like to see, and where most of me questions stem from, is a general overview of the workflow. I didn’t quite find that when I started browsing the documention or video tutorials. The resources are so well done, but felt a little bit scattered. I’d love to see, first on the list, under overview: A section that goes over the general workflow of using ragdoll (with a character), and from there, link to these other articels on how to set up IK markers etc.
I get that you probably don’t want to scare people away with too much information on the get go, and I also get that this would not be suitable for people who just want to “play with physics” in isolated contexts. But for me, and I guess for other people hoping to use the tool in a broader way, as an assisting tool when animating whatever - it would be great!
Your intuition is correct! Let’s see how Ragdoll lines up…
Now you’re thinking like a rigger. Ragdoll tries to do what animators normally do; which is work with the scene they are animating in. So there is generally no need to assign any physics in the original rig file. Instead, you can assign directly in your shot, or at the very least in a scene with the rig already referenced.
It’s possible Ragdoll gets confused here where e.g. the lower arm control doesn’t have a namespace in the original file, and then is expected to import onto one with a namespace. I’ll double check this; it would be an unusual way of Ragdolling.
Make a Maya polygon plane
Assign to it
Set Behaviour = Animated
Were there any errors printed here? It looks like it didn’t manage to finish importing.
Alternatively, could it be that there are other nodes with the same name, under different namespaces? For example, controls:Elbow_L and model:Elbow_L, whereby the markers are imported onto the wrong control? Try using the Match By: Hierarchy just in case.
Bingo.
Let me know if there are any errors in the Script Editor here as well.
Would it be possible to send me the scene file? Alternatively, if you can reproduce this in a smaller scene, maybe just using the Mixamo skeleton.
