Everything works fine until I hit Record Simulation. My character is standing still but has all the keyframes. I looked at the F-Curves and they are practically flat.
I tried using the addon with the simple sphere object and got the same result.
P. S. also when I hit Snap to Simulation it gives me this message: “Ragdoll: This version of Ragdoll is newer than your AUP”
Did you already have a licence for Ragdoll with Maya? The message would indicate that the licence you have included updates 1 year into the future, but this Blender release is past that date hence you would need to renew your Annual Upgrade Program to benefit from newer releases.
It’s also possible the checking algorithm messed up, in which case reach out to me via marcus@ragdolldynamics.com with your serial and I’ll see what we can do.
The cube does have keyframes, but it’s not moving. there’s no animation, the f-curves are flat. I only see the AUP message when I use Snap to Simulation
New version is up! Double-thanks again for reporting this twice @Zack, I did spot the issue and expect to have squashed it now. Please have another go!
