Hello, I can’t manage to get 2 cubes falling and colliding.
Collide is ON
Markers/Cubes assigned to the same group, is this wrong?
Collide is ON
Hi @Sarah_Padoan, welcome to the forums!
I suspect what’s happening is the cubes were assigned together, and are given the same group. The group, per default, has an attribute called Self Collide = Off
since the typical usecase is assigning on limbs of a character, and those limbs would normally not self-collide.
In your case, you can either:
Self Collide = On
for the group your boxes ended up inOption (2) won’t create any group, and thus not have an option to Self Collide
in which case they will collide as two independent boxes.
Let me know if this works, else we can investigate a little more. Also if you can share a screenshot or video of what you are seeing, that always helps.
