Using Ragdoll Dynamics to Add Full-Body Secondary Motion Workflow Advice?
@marcus Your work is great! I’ve been using Ragdoll Dynamics since last night and have been doing some experiments. The learning curve is SO good!! The amount of quality it adds in such a short time is insane. I only need to set up some simple keyframes, and it takes care of all the secondary motion for me.
I’m planning to make a 10-minute animation with around 15 characters. My idea is to keyframe everything first, use Ragdoll Dynamics to add secondary animation, bake the results, and then polish the animation by refining the baked keyframes.
And by “secondary animation,” I don’t mean just hair or clothing. I mean using Ragdoll Dynamics as a way to make the whole animation more fluid and alive, quite close to what this guy did (But i wont use on the face):
Or this example:
Or this other example
I’m still trying to understand exactly HOW i should go about doing it tho. So i’ve been watching your YouTube videos, and they’ve been a massive help, but dont teach EXACTLY this. Do you have any tips or links to videos that teach a similar approach to this workflow? The more detailed the better
Last night experimets:
The gray woman
One of the kids
Then i went to sleep, woke up and made some improviments and other characters
This was my last test until now, later today i will keep working on the other characters, but now i will add their fingers!
To get a better feel of what my level is, this is my twitter
Hi @Yuki, welcome to the forums! :partying_face:
Thanks for sharing your work, and glad to hear you are enjoying Ragdoll. Do keep sharing!
As for the driving example, the trick is two-fold.
  1. A slight increase in Rotate Stiffness
  2. A pinned or Animated lower-body
The Rotate Stiffness will keep simulation closer to animation, and the lower body will transfer motion from the environment into the overall character.
There is more behind-the-scene material here:
Here’s a mini-tutorial I made for you, using our built-in assets.
As you can see, the default stiffness in this case is far too slack. So:
1. Increase stiffness
Now it’ll stay close to animation.
2. Animate hip
With the hip moving with the environment, making it animated transfers all of that motion into simulation. If the environment is simulated too, you can instead use an Attach Constraint for a similar effect.
3. Polish
Finally, tune stiffness to your liking, to preserve as much of the animation as is suitable for the shot.
Amazing, this type of answer is as high-quality as it gets. I’ll make sure to post about my animation when it’s finished (though it will take a while), along with some behind-the-scenes content showing how I used Ragdoll for the whole thing, including the dancing characters.
One last thing: besides the official website and YouTube channel, do you know of any other places where I can learn how to use this tool? A good chunk of the tutorials are unfortunately outdated because of how much the program has changed.
(Btw, i learned a couple of other tricks)
Ooo yes, that walk cycle at the end of your first video looks so good! Try adding a Pin Constraint on the head, remove the Translate Stiffness such that it only controls rotations. That’ll be your “aim constraint”, to keep the head more lively. The rest is superb. :+1:
As for learning resources, the Manipulator UI has changed yes, but tutorials that cover the Maya-side and general functionality are still valid since 2022. Apart from website and YouTube, you’ve got this forum, e.g.
And the learning documentation:
And for most up-to-date examples and reference documentation, we tend to make a spectacle out of our release notes here.
If you were to read all of those, you would have learned pretty much everything there is to know. :slight_smile:
Other than that, we always welcome creators to make tutorials of their own and share here on the forums and social media.
Thank you!!!
