Hi guys ,
I created a rope rig like shown in the ’ crab climb tutorial ’ but the marker size came up too large .Would it be possible to select all of them together and a do a group scale (reduce radius size ) instead of one at a time ?
Hi guys ,
You can select multiple markers if you turn
Symmetry
off
when they are all Selected you can type in a value in the channel box that will effect all of them.
Awesome ,That worked .Thank you so much
One more option is to select the assigned joints/controls in the viewport or Outliner, and pick the Marker from the Channel Box. It will automatically pick all markers of all selected joints/controls, and edit them together.
The Manipulator is getting support for Drag Select and Select Hierarchy, but until then this can help when there is a lot of click click click.
Thanks a lot Marcus it worked .Drag selection would be great to have
Adding this example here as well, for bulk-editing limits, based on this question here.
