My pleasure.
If you end up scaling the crab past 2-10x you might find the crab starts to freak out. To address this, make a quick tweak to this attribute related to mass.
- Select Markers
- Set
Angular Mass = -1
You can use this menu item to select all markers.
And the Attribute Spreadsheet to edit the Angular Mass XYZ attributes.
This is uniquely related to the crab, normally this attribute is already -1 which means the mass is auto-computed. For this particular crab, it can help to make the legs stronger. You can also experiment with higher values, such as 10-100. Depending on how much you scale the crab.
