Hey @magicleo88, welcome to the forums!
Then this definitely sounds like a self-collision issue.
Have a look at this method to visualise where there are contacts.
https://learn.ragdolldynamics.com/releases/2022.03.14/#contact-visualisation
I expect you’ll find some contacts happening inbetween markers in your character, that should give you some idea of which markers are indeed still overlapping.
0 is a special value meaning “respect self-collision”. Meaning that if Self Collide = On
then markers in the same group will collide with each other.
The exception to this, globally, everywhere, is markers that are direct neighbours to each other.
So if you’ve got two markers that do overlap - and you would like to permit this - then you’d give them another value. Anything 2 and above. I’ve found that 1 is another special value that isn’t working correctly, so 2 up to 65,000 or so is safe to use.
-1 is the final special value, meaning "collide with everything in the same group, even if Self Collide = False
The rules are:
- Neighbours may overlap
- Markers in a group with
Self Collide = Off
may overlap - Markers with the same
Overlap Group
number may overlap, except -1, 0 and 1.
That’s about all the control you have here. If you have a scenario in mind that requires more control, then this is the place to let me know!
I do touch on overlap groups and self collision in the recent video just published here:
If this still doesn’t solve your case, feel free to upload your scene (or one like it) and I’d be happy to take a look. Just make sure it’s as small as you can possibly make it, 0-5 mb, and .zip
it too, to keep our precious backups from exploding. Then you can just drag it into a post here.
PS: If you can make a
mp4
instead of agif
, then that would help as we can scrub the video and get some idea of how long it is.
