I just updated to the latest release (2026.10.01) on Maya 2023 from 2025.10.06.
When in Manipulator mode, I can’t interact with anything in the scene. I can interact with all the manipulator’s UI, hotkeys seem to work (In pose mode holding ctrl activates Mask for example) but clicking, middle clicking or right clicking on Ragdoll capsules doesn’t do anything at all.
I am investigating this at the moment. I have checked viewport rendering engine in Maya preference myself, OpenGL and DirectX both working in Maya 2023.
Can you share some screen recording, and the text in Maya’s Output Window? There should have some more clues.
The character I was using previously had an older version of Ragdoll applied in the scene. When I noticed I couldn’t select anything with the manipulator I tried deleting all physics and building some fresh capsules. But the manipulator still didn’t work.
So then I tried opening a brand new scene, referenced in the same character fresh and assigned some capsules. Now the manipulator works!
So something about the original scene is the issue, even though the manipulator was working correctly with it in 2025.10.06.
Unfortunately because of company policies I don’t think I can post a screen recording, but in the problem scene this is what prints entering manipulator mode after new capsule assignment :
from ragdoll import interactive as ri;ri.assign_and_connect()
# Result: True
from ragdoll import interactive as ri;ri.markers_manipulator()
# ragdoll.markers_manipulator() - Manipulating rMarker_Head_ctrl
# Result: True
Then the only things I can get it to print after that are UI interactions.
// Mode changed to Live Mode
// Mode changed to Playback Mode
// Mode changed to Limit Mode
Clicking on capsules produces no output.
So a simple fix for now will just be taking some time to rebuild my character’s ragdoll setup in a new scene.
Hm, we had a similar issue the other week. Can you try making a new camera, and selecting through that? The Near Clip Plane and Far Clip Plane tend to mess with selection sometimes.
